![]() | Home > Maintenance & Modifications > Sagging rear wheel |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1205 ![]() ![]() ![]() |
Hi everyone,
anyone? |
found this very useful fuse guide, but the EAS one is not in there?
So yesterday I used the GAP tool to lift the sagging wheel, and then I did not re-enable the EAS when exiting the routine.
Do you know if I can do this with the Gap tool? --
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 783 ![]() ![]() ![]() |
I don't but would be surprised if you can't. I'm sure a veteran IID user will be along shortly. |
naks, when the car is running, does it inflate to the correct height? If not, you may wish to run the calibration routine on the IID tool, in case the cal values are out of whack. Kev
well, the issue never occured again.
