Home > Maintenance & Modifications > Sagging rear wheel |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1125 |
Hi everyone,
Tue Jun 08 2021 3:28pm |
anyone? --
Wed Jun 09 2021 8:00am |
found this very useful fuse guide, but the EAS one is not in there?
Wed Jun 09 2021 9:53am |
So yesterday I used the GAP tool to lift the sagging wheel, and then I did not re-enable the EAS when exiting the routine.
Thu Jun 10 2021 8:22am |
Do you know if I can do this with the Gap tool? --
Thu Jun 10 2021 1:41pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
I don't but would be surprised if you can't. I'm sure a veteran IID user will be along shortly. |
Thu Jun 10 2021 6:39pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
naks, when the car is running, does it inflate to the correct height? If not, you may wish to run the calibration routine on the IID tool, in case the cal values are out of whack. Kev
Thu Jun 10 2021 9:29pm |
well, the issue never occured again.
Mon Jun 28 2021 10:02am |
