Home > Maintenance & Modifications > Wheel bearing/Driveshaft/Props/Front Lower Arms |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Just had the OSF wheel bearing changed on mine at 118k.
Tue Jun 01 2021 10:30pm |
MarcMGD Member Since: 30 Nov 2020 Location: Essex Posts: 22 |
Hi mate,
Tue Jun 01 2021 11:02pm |
My indie fitted genuine item. 2012 SDV6 - it's missing a couple of cylinders
Wed Jun 02 2021 1:18am |
Anyone have anything else I need to look at? Any chance it's driftshaft or cv joint related? |
Fri Jun 04 2021 11:27pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 919 |
Had issues with mine when I first bought it,, had about 82k on the clock. I replaced all discs and pads as they were really bad but still had a rumbling noise on right hand corners. Had lower front arms done and both front bearings,,, the difference was night and day,, like driving a new car, front end far more responsive and no more rumbles or rattles. 2010 RRS, TDV8
Sat Jun 05 2021 9:17pm |
I have ordered a new wheel bearing which I will fit on Friday I'll keep this thread updated with how I go. I will then confirm if there is any improvement. |
Wed Jun 09 2021 9:20pm |
Just to update this for others, I changed my drivers front wheel bearing today for a new Meyle one from Advanced Factors. It took about 45-hour and saved a few £'s.
Fri Jun 11 2021 9:22pm |
Just to update this further, changed my rear drop links and bushes a few weeks ago, just done my lower front arms today didn't managed to get it tracked but went off the old markings will get it tracked on a hunter Tuesday on the people next door to work. Not a job for the feint hearted but easily manageable if you have a decent recip saw decent blades.
Sat Aug 28 2021 8:11pm |
