![]() | Home > Maintenance & Modifications > Wheel bearing/Driveshaft/Props/Front Lower Arms |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9152 ![]() ![]() ![]() |
Just had the OSF wheel bearing changed on mine at 118k.
MarcMGD Member Since: 30 Nov 2020 Location: Essex Posts: 22 ![]() ![]() ![]() |
Hi mate,
My indie fitted genuine item. 2012 SDV6 - it's missing a couple of cylinders
Anyone have anything else I need to look at? Any chance it's driftshaft or cv joint related? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
Had issues with mine when I first bought it,, had about 82k on the clock. I replaced all discs and pads as they were really bad but still had a rumbling noise on right hand corners. Had lower front arms done and both front bearings,,, the difference was night and day,, like driving a new car, front end far more responsive and no more rumbles or rattles. 2010 RRS, TDV8
I have ordered a new wheel bearing which I will fit on Friday I'll keep this thread updated with how I go. I will then confirm if there is any improvement. |
Just to update this for others, I changed my drivers front wheel bearing today for a new Meyle one from Advanced Factors. It took about 45-hour and saved a few £'s.
Just to update this further, changed my rear drop links and bushes a few weeks ago, just done my lower front arms today didn't managed to get it tracked but went off the old markings will get it tracked on a hunter Tuesday on the people next door to work. Not a job for the feint hearted but easily manageable if you have a decent recip saw decent blades.
