![]() | Home > Technical > Unlocking Range Rover Sport |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5076 ![]() ![]() ![]() |
Does the spare work ?
baldy46 Member Since: 07 Apr 2021 Location: LINCOLNSHIRE Posts: 7 ![]() ![]() ![]() |
hi Andy, no both arnt working,,? |
where would I buy these from, how much roughly would a dealer charge etc, to cure the problem, im a bit stuck at moment as you may of guessed, my thob is 1 of those they say are sealed from factory, , any help would be great, many thanks |
There maybe a wire splice joint (green wire) in the passenger sill that needs redoing or a receiver fault.
ok ,thanks ill see what I find, and thanks again
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
does it unlock with the manual key? |
I'm not sure early cars activate the central locking from the passenger barrel |
Hi all took passenger door cap off.unlocked door .opened bonnet.battery only had 2 volts...put on charge doors open with thob.so battery on charge now... thanks for all replies
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
I don't hold out much hope for your battery if it's down to 2 volts,,, maybe it's time for a new one 2010 RRS, TDV8
hi gogsy, the battery is 5 years old,,, i just dont use the sport as much as use to, and also i found out 1 of the front inside lights had been left on ??? id say that made him flat as not been used in at least 2 weeks, |
I've put 2 batteries on mine,,, plus the original som3 in total, I think your lucky if you get 4 years out of a battery,, the RR is quite greedy in that dept. I would get a smart charger on it for a couple of days and see if it comes back to life and I would make a habit of charging it at least once a week if your not using it. 2010 RRS, TDV8
Cheers m8y....I'm in it now... seems all ok...had the best 13 years now... love it. Still same condition as wen I got it... brilliant car....but car tax is a killer... |
