Home > Technical > Unlocking Range Rover Sport
baldy46
United Kingdom 2007 Range Rover Sport TDV6 SE Zermatt Silver
hi my sport wont unlock,with key thob ,think my battery needs replacing how is the best to resolve this, go to Land Rover Dealer ?? year 2007
Post #612368 Wed Apr 07 2021 9:59pm
Does the spare work ?
You could buy a programmer for £60 and a key for £20 which is cheaper than landrover
https://www.disco3.co.uk/forum/topic194079.html
Post #612371 Wed Apr 07 2021 10:27pm
baldy46
hi Andy, no both arnt working,,?
Post #612372 Wed Apr 07 2021 10:30pm
baldy46
where would I buy these from, how much roughly would a dealer charge etc, to cure the problem, im a bit stuck at moment as you may of guessed, my thob is 1 of those they say are sealed from factory, , any help would be great, many thanks
Post #612373 Wed Apr 07 2021 10:34pm
There maybe a wire splice joint (green wire) in the passenger sill that needs redoing or a receiver fault.
This is more likely than a battery fault.
Batteries charge when in the ignition or on an electric tooth brush base
Post #612374 Wed Apr 07 2021 10:51pm
baldy46
ok ,thanks ill see what I find, and thanks again
regards
Post #612377 Wed Apr 07 2021 10:59pm
scarey
does it unlock with the manual key?
Post #612388 Thu Apr 08 2021 2:47pm
I'm not sure early cars activate the central locking from the passenger barrel
Post #612389 Thu Apr 08 2021 2:49pm
baldy46
Hi all took passenger door cap off.unlocked door .opened bonnet.battery only had 2 volts...put on charge doors open with thob.so battery on charge now... thanks for all replies
Regards
Post #612390 Thu Apr 08 2021 3:42pm
gogsy1956
I don't hold out much hope for your battery if it's down to 2 volts,,, maybe it's time for a new one 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #612391 Thu Apr 08 2021 4:13pm
baldy46
hi gogsy, the battery is 5 years old,,, i just dont use the sport as much as use to, and also i found out 1 of the front inside lights had been left on ??? id say that made him flat as not been used in at least 2 weeks,
Post #612393 Thu Apr 08 2021 6:39pm
gogsy1956
I've put 2 batteries on mine,,, plus the original som3 in total, I think your lucky if you get 4 years out of a battery,, the RR is quite greedy in that dept. I would get a smart charger on it for a couple of days and see if it comes back to life and I would make a habit of charging it at least once a week if your not using it. 2010 RRS, TDV8
22" overfinch
Post #612396 Thu Apr 08 2021 8:34pm
baldy46
Cheers m8y....I'm in it now... seems all ok...had the best 13 years now... love it. Still same condition as wen I got it... brilliant car....but car tax is a killer...
Post #612426 Fri Apr 09 2021 5:36pm
