Home > General (L494) > Drive train knock
Lml
England 2013 Range Rover Sport SDV6 HSE Stornoway Grey
Drive train knock
Good evening all.
I have a 2014 L494. I have a knocking coming from the drive train somewhere. It seems to happen after you hit a pot hole or have wheels off the road on the verge but only at slow speed. As you drive you can feel the vehicle almost jolting as you drive. It’s a difficult one to describe. I don’t know if it’s related but I also have what sounds like a suspension knock but that also seems to come and go and I can’t get it to knock every time. Anybody experienced anything similar?
Thanks
Post #607218 Fri Dec 04 2020 11:03pm
Lml
Bit more detail. I have worked out today that I think it is a dif locking up momentarily. It doesn’t start knocking until you hit a pot hole or spin a wheel on the verge. When I watch the 4x4 info you can see the difs light up briefly when it first starts.
Post #607242 Sat Dec 05 2020 9:43pm
Lml
Update for anyone else with similar problems. Vehicle went into main dealer last week as it was due a service anyway. They diagnosed a faulty transfer box. They have done a double flush (changed the oil twice) on the transfer box and it now all seems ok. There is a bulletin out for this fault LTB00906NAS4.
Post #607623 Thu Dec 17 2020 10:40pm
I'm surprised they change the oil twice but I guess they're using the first change to clean out any build up of sludge (or whatever the oil does when it deteriorates).
Hopefully that's solved the problem for you. Thumbs Up
Thanks for sharing with the forum, it helps us build up a knowledge base for the future. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #607628 Fri Dec 18 2020 10:48am
