Home > General > Help.....UPDATE
Greyhound
United Kingdom 2013 Range Rover Sport Supercharged Santorini Black
Help.....UPDATE
Parked up as normal 5 days ago .Last night I tried to start it ,everything electrical was working but the engine was completely dead and it would not turn over .it goes through the system check and then says transmission fault then engine system fault and F on the dashboard ..The battery is just 12 months old but it was at half charge so I put it on overnight charge .I tried to jump start it but it wont as it is completely dead
Post #603472 Thu Aug 20 2020 6:55am
I think I would initially start by having the battery tested, could well have a dead cell even at twelve months old, what make of battery is it?
Post #603474 Thu Aug 20 2020 7:08am
Greyhound
its just a cheap battery excide excel I have just put the charger back on and the battery is back at half charge ,,the charger is charging it but after an hour it stops charging ...why wont it accept a jump start though
Post #603475 Thu Aug 20 2020 7:22am
Are you connecting the earth lead to the battery terminal or a good earth point on the engine? as it is is suggested by L/R you use a good earth point on the engine.
Post #603476 Thu Aug 20 2020 7:33am
Greyhound
I have tried both ways
It wont attempt to turn over either with jump leads or a power pack
Post #603477 Thu Aug 20 2020 7:46am
Does anything happen when you press the stop start button?
Post #603478 Thu Aug 20 2020 8:01am
Greyhound
its a key start it goes through system check and then wont go any further and turning the key does nothing
Post #603479 Thu Aug 20 2020 8:06am
Your Avatar says you have a 2013 S/C if that is the case it would be Keyless entry with push button start not a key start.
Post #603480 Thu Aug 20 2020 8:10am
Greyhound
I also have a 2007 supercharged and its this that I have the problem with
Post #603481 Thu Aug 20 2020 8:13am
In that case why not just swap the batteries over initially which would eliminate the battery side of things.
Post #603482 Thu Aug 20 2020 8:17am
If it's not the battery then it's a full code read required to even start figuring it out. Could be as simple as an earth point failure, could be something much more nasty. 2012 SDV6 - it's missing a couple of cylinders
Post #603486 Thu Aug 20 2020 9:09am
There is a relay under the bonnet box marked SM
Starter motor
Could swap it for another one.
If the dash is lit up with errors then it’s prob something else.
Have you done a battery disconnect for 20 mins ?
Post #603491 Thu Aug 20 2020 10:16am
Greyhound
UPDATE
The land rover mechanic came out last night and the diagnostics indicated that the ECU could not locate the engine ??? After several electrical check including all relays,fuses,battery,alternator and starter he told me it would have to go into the garage as he had never seen this issue before ...as a last resort and out of desperation I asked him if he would spanner the negative to the positive and try and re set the ecu …..5 minutes later the engine fires and all the faults have disappeared and diagnostics confirm everything is working fine .
It has been ok today and had never given any trouble before this incident so fingers crossed it was just an unexplained gremlin
Post #603552 Fri Aug 21 2020 1:00pm
Lol
Result
Post #603555 Fri Aug 21 2020 1:54pm
knwatkins
 Kev
Post #603569 Fri Aug 21 2020 4:04pm
