![]() | Home > General > Help.....UPDATE |
I think I would initially start by having the battery tested, could well have a dead cell even at twelve months old, what make of battery is it?
Greyhound Member Since: 03 Oct 2015 Location: Cheshire Posts: 21 ![]() ![]() ![]() |
its just a cheap battery excide excel I have just put the charger back on and the battery is back at half charge ,,the charger is charging it but after an hour it stops charging ...why wont it accept a jump start though |
Are you connecting the earth lead to the battery terminal or a good earth point on the engine? as it is is suggested by L/R you use a good earth point on the engine.
I have tried both ways
Does anything happen when you press the stop start button?
its a key start it goes through system check and then wont go any further and turning the key does nothing |
Your Avatar says you have a 2013 S/C if that is the case it would be Keyless entry with push button start not a key start.
I also have a 2007 supercharged and its this that I have the problem with |
In that case why not just swap the batteries over initially which would eliminate the battery side of things.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9124 ![]() ![]() ![]() |
If it's not the battery then it's a full code read required to even start figuring it out. Could be as simple as an earth point failure, could be something much more nasty. 2012 SDV6 - it's missing a couple of cylinders
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
There is a relay under the bonnet box marked SM
UPDATE
Lol
