![]() | Home > General > Front Parking Sensors - on the blink |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
On my 2008 the sensors, front and rear, only come on automatically if I select reverse. The button on the dash is there to switch them on if you are driving forward into a parking space or to turn the sensors off if you don't need them - for example when off-road. So it sounds to me that this is how yours are and how they should be Robin
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
Very early ones were different
SlipperyKipper Member Since: 24 Jun 2020 Location: Hereford Posts: 28 ![]() ![]() |
Mine done the same at one point - Interestingly when the battery went flat and I recharged it, the problem went away! |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 344 ![]() ![]() ![]() |
Thanks for all the input....however still looking for the solution to the problem Andrew Kennedy |
