Home > General > Front Parking Sensors - on the blink
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. After driving for a period and coming to, lets say for example a brick wall in front of me (car in 'D') my front parking sensors will only pick up the problem and report with a 'bleep' if I hit the switch on the dash to activate the system? The reverse sensors are working (automatically) when in 'R' as they should. I'm hoping its simple a switch problem!?!? Andrew Kennedy
Post #602746 Tue Aug 04 2020 8:23pm
Eaters
On my 2008 the sensors, front and rear, only come on automatically if I select reverse. The button on the dash is there to switch them on if you are driving forward into a parking space or to turn the sensors off if you don't need them - for example when off-road. So it sounds to me that this is how yours are and how they should be Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #602751 Tue Aug 04 2020 9:43pm
Very early ones were different
Depends on ecu fitted.
The thing to do is slow down below 10mph and see if the switch light comes on automatically
Post #602756 Tue Aug 04 2020 10:06pm
SlipperyKipper
Mine done the same at one point - Interestingly when the battery went flat and I recharged it, the problem went away!
Post #602757 Tue Aug 04 2020 10:06pm
andrew kennedy
Thanks for all the input....however still looking for the solution to the problem Andrew Kennedy
Post #602771 Wed Aug 05 2020 8:26am
