Home > Maintenance & Modifications > Difference in diff oils
derekmines
So I'm looking at replacing front and rear diff oils on the car, comma say that the f+r diffs both take the same 75/90 oil
Whilst other sites give a different LR part code for the rear oil if the car has an electronic locking diff (mine does I believe)
Despite having different part codes, both those oils are also 75/90
What's the correct thing to do here? Is there a difference in the oils or are we safe to use the standard Comma 75/90 in both?
Post #598089 Fri Apr 24 2020 3:05pm
As the drive line oil gets changes so infrequently , just use the proper Castrol stuff.
In gold bottle for front
Post #598091 Fri Apr 24 2020 4:10pm
knwatkins
75w90 fully synthetic gear oil with an API service category of GL-5 is what you need for the front diff and also rear open (non-locking) diff.
If you have the electronic locking rear, you will need a different fluid specifically designed for multi-disc locking diffs. I'm not sure what the actual technical spec is for this, but LR originally specified Castrol SAF – Carbon Mod Plus. This is no longer manufactured and I believe Castrol BOT 720 is the superseding product. Equivalents from other brands would be Ravenol MDL and Rock Oil Gearaxl MDL.
For my front and non-locking rear, I use Smith & Allan fully synthetic 75w90 which meets the GL-5 service category. £12.84 for 5 litres. https://www.smithandallan.com/products/tra...fs-75w-90/
0.6 litres in the front diff, 1.1 litres in a non-locking rear or 1.8 litres in an electronic locking rear. Kev
Post #598104 Fri Apr 24 2020 11:14pm
Re: Difference in diff oils
The locking rear diff has a multiplate wet clutch that gives the locking effect. The oil is chosen to work with that so the correct oil should be provided. 2012 SDV6 - it's missing a couple of cylinders
Post #598108 Sat Apr 25 2020 12:46am
