![]() | Home > Maintenance & Modifications > Difference in diff oils |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5114 ![]() ![]() ![]() |
As the drive line oil gets changes so infrequently , just use the proper Castrol stuff.
75w90 fully synthetic gear oil with an API service category of GL-5 is what you need for the front diff and also rear open (non-locking) diff.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9109 ![]() ![]() ![]() |
The locking rear diff has a multiplate wet clutch that gives the locking effect. The oil is chosen to work with that so the correct oil should be provided. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
