![]() | Home > Technical > Front Lower Arm Advice Please |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Early RRS.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
Meyle HD arms
Thanks.
If the front bush and ball joint are OK, then rebush
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5136 ![]() ![]() ![]() |
Recently fitted a set of the Meyle arms from Advanced Factors, fitted perfectly with no problems and looked top quality, whole kit cost less than price of one arm from L/R. Did try arms with Poly bushes first but found them a little harsh for my liking, so fitted the rubber one's instead. Not the nicest job to do if you don't have a ramp but not to a difficult job. I was fortunate in the fact that only one bolt was seized and had to be cut off.
As above, Meyle HD front arms. I have these on mine and and they are great.
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
+ 1 for Myle, i fitted mine approx 40k miles ago and not had a problem. Have been off road and both motorway and twisty roads of Scotland so defiantly well used....
