Home > Technical > Front Lower Arm Advice Please
Stuart
Early RRS.
The front lower arms are knocking. They have been for a while and although it passes the MOT test, it's time to do them.
The indy I use recommends I fit genuine ones and says its a few hours of a job so not cheap.
Are the cheap ones on eBay generally any good or is it a false economy?
What might be the typical time it takes to change them?
Is this the type of job best left to an indy familiar with them or can any half decent (non RRS specialist) garage do this job?
Just trying to figure out the best way to go with the job without having my hat nailed on if I can avoid it. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #596893 Mon Mar 23 2020 7:01pm
Disco_Mikey
Meyle HD arms
Not the cheapest, but certainly one of the better suspension arms I've ever fitted. Been fitting them for around 3.5 years now, and they come with a 4year warranty
Never had to replace one even after all this time Thumbs Up
Or, Superpro bushes if you want to rebush them
Post #596894 Mon Mar 23 2020 7:04pm
Stuart
Thanks.
Would you replace them or re-bush them, Mike? What is typically done?
How long does it take to do both sides? Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Post #596895 Mon Mar 23 2020 7:07pm
Disco_Mikey
If the front bush and ball joint are OK, then rebush
If the arms are old and rusty, then rebush Thumbs Up
Post #596899 Mon Mar 23 2020 8:37pm
Do you mean replace if the arms are old and rusty? 2012 SDV6 - it's missing a couple of cylinders
Post #596901 Mon Mar 23 2020 8:47pm
Recently fitted a set of the Meyle arms from Advanced Factors, fitted perfectly with no problems and looked top quality, whole kit cost less than price of one arm from L/R. Did try arms with Poly bushes first but found them a little harsh for my liking, so fitted the rubber one's instead. Not the nicest job to do if you don't have a ramp but not to a difficult job. I was fortunate in the fact that only one bolt was seized and had to be cut off.
https://www.advancedfactors.co.uk/kit630-h...7241-p.asp
Post #596911 Mon Mar 23 2020 10:59pm
knwatkins
As above, Meyle HD front arms. I have these on mine and and they are great.
The rearmost hydrabush, which is the one that is most prone to failure, is replaced with a solid rubber one so will last a long time.
Don't forget the discount code AF4LRP. It will get you 5% off. Kev
Post #596912 Mon Mar 23 2020 11:27pm
PC76
+ 1 for Myle, i fitted mine approx 40k miles ago and not had a problem. Have been off road and both motorway and twisty roads of Scotland so defiantly well used....
Ramp is defiantly a bonus & a very good impact gun is a must!!!!
don't forget 4 wheel alignment afterwards
Post #597058 Thu Mar 26 2020 11:17pm
