Home > General > Coolant leak 400 miles from home |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
I remember an article about a steel into rubber hose down by the thermostat and the hose ran down passenger side of the engine (2.7). They found it just by chance and the steel had corroded on the outside which caused coolant loss.
Thu Mar 05 2020 6:02pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
Thanks steve.. will hopefully have a chance to have a look tomorrow...
Thu Mar 05 2020 6:48pm |
on my way home last night i deared take the car up to 2k reves, the water level dropped very quickly say less than 30miles as i had to pull in to the next servicdes after topping it up.
Fri Mar 06 2020 11:40am |
Hi All, i believe i have identified where the leak is coming from. please see the below photo. this is under the Throttle body (sorry corrected) at the top centre of the engine. this was hissing with very fine bubbles when the engine revved.
Fri Mar 06 2020 5:55pm |
I think i have identified the part, LR73372 Water connector.
Fri Mar 06 2020 7:30pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
The second turbo kicks in at about 2800rpm. Glad you got home in the end. Fingers crossed replacing that will solve the problem. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Fri Mar 06 2020 7:41pm |
Please see pic below, the coolant had not spilt out as the system was low already so was already there.
Sat Mar 07 2020 1:18pm |
Update: Leak fixed, no need to swap the o-ring on the oil filter housing as replacing the water connector (LR73372) sorted the problem. The part was held in stock which is telling in it's own right by lrparts.net who are based within 20miles so managed to get there and back with no issues
Tue Mar 10 2020 9:13pm |
Well done mate. Good to know. Robin
Wed Mar 11 2020 8:33am |
