![]() | Home > Maintenance & Modifications > Transfer box oil & Locking differential oil |
drexal Member Since: 18 Dec 2019 Location: london Posts: 117 ![]() ![]() ![]() |
Hi guys,
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 960 ![]() ![]() ![]() |
wise words,,,, i'm quite competant aand i wouldnt even consider doing a job like that 2010 RRS, TDV8
It's easy enough to do yourself. Don't be afraid. Undo the plugs, drain the fluid and refill. Fluids are the easiest things to do on your vehicle yourself to maintain it.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Does your vehicle actually have a rear locking diff? I ask this as different oil is used for the locking diff vs the normal diff.
Hi guys, sorry for no reply till now.
I’ve got this
Ah perfect Stevepd thank you |
If you watch the video I posted above, the guy in videos shows you how you identify the locking vs open diff ![]() I have one of these, but it's completely rubbish... https://www.amazon.co.uk/Sealey-AK46-Sucti...B000RA0XLO So I now have a small electric pump... https://ebay.us/bkyMTW Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Ah interesting, yes i have seen clips of people struggling to pump fluids with these pumps. So an electric pump looks ideal.
You can do that yourself on Topix...
Another great tip, thanks Kev. Wow awesome to see all that info about the rrs i didn't know.
No problem |
teldec Member Since: 29 Dec 2019 Location: essex Posts: 88 ![]() ![]() |
I have just had a quote to change mine and its 108-00 with oils so will get it done at the next service rather than mess around under the car myself |
Thanks Teldec, could i ask the name of your indy, as i'm in east london, so they might not be that far from me if i chicken out of doing this myself? 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black |
