Home > Maintenance & Modifications > Transfer box oil & Locking differential oil
drexal
United Kingdom 2012 Range Rover Sport Supercharged HSE Santorini Black
Hi guys,
I have just noticed in 2017 my 2012 RRS V8 SC service it should of had the Transfer box oil & Locking differential oil changed as part of that service, maybe because the car had only done 45,000 miles at the time and this is the 75,000 mile service he didn't think it needed it. So he only had the oil & filter changed. But none of the subsequent services ask for this to be done, so as i would love to keep this L320 as long as i can i really want to look after it. And so i'm planning on trying to do this myself.
Has anyone on here ever done and this themselves? If you have any info on how it's done, or if you think i should leave to an indy please let me know. Also what oil and how much is needed for the transfer and diff? Just thought i would see anyone had any tips before i spend hours searching online & trying to find it in my manual on how to do this myself.
ps i'm a novice on car maintenance and don't have a lift etc. 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #594848 Fri Feb 14 2020 3:05pm
Get your indy to do it. For the few quid you save doing it on your drive, you spend the time getting cold, wet and covered in old oil instead.
If you do decide to do it yourself, the single most important tip is this one: undo the filling bolt before you undo the draining bolt. That way, you know that you can refill it. If you drain it and then can't open the filling port, you're stuck! Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #594852 Fri Feb 14 2020 4:33pm
gogsy1956
wise words,,,, i'm quite competant aand i wouldnt even consider doing a job like that 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #594860 Fri Feb 14 2020 8:01pm
knwatkins
It's easy enough to do yourself. Don't be afraid. Undo the plugs, drain the fluid and refill. Fluids are the easiest things to do on your vehicle yourself to maintain it.
Watch this video and you'll realise how simple a job it is...
As RRSTDV8 mentioned, always undo the fill plug first, then the drain plug. When filling back up, fill using the correct volume of fluid.
For your transfer box, you will need 1.5 litres of fluid that meets or exceeds the Shell spec TF-0753. The LR part number for this is IYK500010.
For example...
Ravenol DTF-1
Rock Oil Gearaxl TF0870
Smith & Allan Transfer Fluid 0753 (Personally, I use this)
As you have the electronic locking rear diff, you will need 1.8 litres of 75w90 diff oil without the friction modifiers. The LR part number for this is LR019727.
For example, the following fluids are suitable...
Ravenol MDL
Castrol BOT 720 / Carbon Mod Plus
For the sake of completeness, your front diff and also for those folks who have the open rear diff (non-locking), a GL5 gear oil with a viscosity of 75w90 is required. 0.6 litres in the front, 1.1 litres in the rear. The LR part number for this is TYK500010.
For example...
Ravenol VSG
Castrol SAF-XO Synthetic
Smith and Allan Geartech FS 75w-90 (Personally, I use this)
I hope this helps Thumbs Up Kev
Post #594874 Fri Feb 14 2020 10:55pm
garrycol
Australia
Does your vehicle actually have a rear locking diff? I ask this as different oil is used for the locking diff vs the normal diff.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #594880 Sat Feb 15 2020 2:28am
drexal
Hi guys, sorry for no reply till now.
Thanks so much for all the advice, so awesome to be part of this club.
And thanks knwatkins for the huge amount of info, incredible work.
And yes good point garrycol, i've gone through my manual but can't see anything relating to this, so i guess i will have to watch all of the atlantic british videos to see if they show one with difference on the electronic diff so i can check mines, or research this more online, also i just hope there not different on the 2012's to the 2006 thats in the video.
Do you guys know if the fluid bottles are shaped so you can poor them straight into the fill holes, or do a need a special tool or funnel for this?
thanks again. 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #594923 Sat Feb 15 2020 7:03pm
Stevepd
I’ve got this
https://www.amazon.co.uk/gp/product/B00474...&psc=1
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #594924 Sat Feb 15 2020 7:27pm
drexal
Ah perfect Stevepd thank you Thumbs Up 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #594926 Sat Feb 15 2020 8:16pm
knwatkins
If you watch the video I posted above, the guy in videos shows you how you identify the locking vs open diff Wink
I have one of these, but it's completely rubbish...
https://www.amazon.co.uk/Sealey-AK46-Sucti...B000RA0XLO
So I now have a small electric pump...
https://ebay.us/bkyMTW Kev
Post #594933 Sat Feb 15 2020 10:01pm
drexal
Ah interesting, yes i have seen clips of people struggling to pump fluids with these pumps. So an electric pump looks ideal.
Ah sorry kev, i did watch it but the baby started crying as i was watching so i must of missed that part. But was planning on watching it again before ordering anything.
I just looked through all the paper work from the original owner for my RRS and found this features info. Weirdly it looks like mine has an open rear diff!
Please see attachment.
But i will climb under and have a look myself after watching the video.
Also apparently you can ring LR and give them your vin and they can check your build/spec to triple check this.
Thanks again everyone. 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #594935 Sat Feb 15 2020 10:43pm
knwatkins
You can do that yourself on Topix...
https://topix.landrover.jlrext.com
Just register with your VIN and you'll be able to access the configuration of the car when it was new.
Most cars have the open diff because the electronic locking rear one was an optional extra. Kev
Post #594941 Sat Feb 15 2020 11:27pm
drexal
Another great tip, thanks Kev. Wow awesome to see all that info about the rrs i didn't know.
And yes that confirms it, its a open rear diff, so least i 100% know what fluid i need to order now Thumbs Up 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #594953 Sun Feb 16 2020 12:43am
knwatkins
No problem Thumbs Up Kev
Post #594961 Sun Feb 16 2020 6:56am
teldec
I have just had a quote to change mine and its 108-00 with oils so will get it done at the next service rather than mess around under the car myself
Post #594988 Sun Feb 16 2020 12:49pm
drexal
Thanks Teldec, could i ask the name of your indy, as i'm in east london, so they might not be that far from me if i chicken out of doing this myself? 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #595003 Sun Feb 16 2020 3:34pm
