Home > General > Question regarding oil changes
Eskimo
Couple of quick questions for you all out there in RRS land......
Have any of you used a pump to pump out the engine oil (via the dipstick) and if so which one have you got?
The reason for asking is that I would need to change the oil on the roadside outside my house so need to try and reduce the chances of any oil spills on the road/pavement.
I figure a pump would be the best option for this as it is hopefully more controllable than via the sump plug. 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
1999 Discovery 4.0 V8 (Gone but not forgotten)
1997 Range Rover 3.5 V8 (Long gone now)
1966 Series II SWB with RR 3.5 V8 (Never finished, now sold)
Post #594261 Mon Feb 03 2020 2:32pm
Tyrefitter
This is the one I have & works fine,just make sure the engine oil is hot to make it easier to remove.
https://www.ebay.co.uk/itm/7L-Manual-Pump-...SwT9Zd6b3S Andy.
21 Ford Ranger
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #594264 Mon Feb 03 2020 3:13pm
DrRob
The Draper 10L is the pump of choice for Full Fat folk Thumbs Up
https://www.fullfatrr.com/forum/topic41966.html * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #594267 Mon Feb 03 2020 5:23pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
+1 for the Draper
Draper 77057 Manual and Pneumatic Oil Extractor
i got one this year.
great job and very quick.
i always did the 2.7l the traditional way but that was when sump plugs were fitted in normal place to drain.
.... but then the 3.0 sump plug is a bitch to get off and not have oil go every where due to the cross member proximity to the oil exit flow 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #594286 Mon Feb 03 2020 11:39pm
Gjlatz
Scotland 2012 Range Rover Sport SDV6 HSE Lux Siberian Silver
Hi, I use an extractor to vacuum out the oil via the extraction port. Oil and filter takes about 30 minutes.
Post #594373 Wed Feb 05 2020 8:55am
