Home > Maintenance & Modifications > L320 SC 4.2 Fuel filter location and which to use?
mgrover
Anyone know where the fuel filter is and whats a replacement? also where the fuel pump is as well? Is it under the rear passenger seat?
Post #592466 Sat Dec 28 2019 7:20pm
Fuel filter and pump are a complete unit and it is situated inside the fuel tank and you need to remove tank to replace it, as the filter is a integral part of the pump you cannot replace it separately or certainly never used to be able to, unless something is now available as aftermarket.
Post #592470 Sat Dec 28 2019 9:39pm
mgrover
what for the 2006 model? Please tell me your wrong because that seems super hard to DIY Razz
Post #592471 Sat Dec 28 2019 9:49pm
Sorry was thinking of the 5.0l S/C. It would appear there is a separate filter for the 4.2 WFL500010 but not sure where it is actualy located.
Post #592473 Sat Dec 28 2019 9:56pm
mgrover
thank Censored because i have constant fuel trim and lean issues, just had both heads rebuilt and didn't fancy forking out even more Razz
Post #592475 Sat Dec 28 2019 10:09pm
Out of curiosity found this, it looks like it maybe in tank but hopefully I'm wrong.
Post #592477 Sat Dec 28 2019 10:33pm
mgrover
I think you are right tbh, fml. Thanks for the help Smile I'll have to see how much hassle it is to drop the tank without a lift.
Post #592479 Sat Dec 28 2019 10:39pm
