Home > Maintenance & Modifications > L320 SC 4.2 Fuel filter location and which to use? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4844 |
Fuel filter and pump are a complete unit and it is situated inside the fuel tank and you need to remove tank to replace it, as the filter is a integral part of the pump you cannot replace it separately or certainly never used to be able to, unless something is now available as aftermarket.
Sat Dec 28 2019 9:39pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
what for the 2006 model? Please tell me your wrong because that seems super hard to DIY |
Sat Dec 28 2019 9:49pm |
Sorry was thinking of the 5.0l S/C. It would appear there is a separate filter for the 4.2 WFL500010 but not sure where it is actualy located.
Sat Dec 28 2019 9:56pm |
thank because i have constant fuel trim and lean issues, just had both heads rebuilt and didn't fancy forking out even more |
Sat Dec 28 2019 10:09pm |
Out of curiosity found this, it looks like it maybe in tank but hopefully I'm wrong.
Sat Dec 28 2019 10:33pm |
I think you are right tbh, fml. Thanks for the help I'll have to see how much hassle it is to drop the tank without a lift. |
Sat Dec 28 2019 10:39pm |
