Home > In Car Electronics > Rear Sensor problem
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Rear Sensor problem
2006 Sport. The rear sensors have a mind of their own!! 50/50 they work correctly when I engage reverse - or - they stay permanently on for no reason. The local Range Rover people have had a look at the problem a couple of time (when I'm in their garage they work correctly...naturally). They have checked the system with a computer and suggest its most likely to be an electrical fault. I'm in France - computer not telling them exactly where the problem is, so, hands in the air, that's that. Can anyone out their advise me of the likely cause of the problem if it is an electrical? Andrew Kennedy
Post #591178 Fri Nov 29 2019 11:03am
it will be one sensor at fault.
When this happened to me, I carried around my IID.
When the fault occurs, plug it in, read the live values of the rear sensors.
The one that is reporting a short distance 0.5m when not parked near anything is faulty
Post #591191 Fri Nov 29 2019 3:08pm
Eaters
I believe some find it possible to listen by each sensor and hear which one is not working.
If it is electrical its not a hugely difficult job to get the rear bumper off and have a look at the loom. (If I can do it then anyone can). When I did this to fix mine, I found that someone had already done a botched wiring job on the original LR wiring. My guess is that the LR wiring leaves a lot to be desired.
Here's a link to my post if its of any help.
https://www.rrsport.co.uk/forum/topic48459...ng+sensors Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #591231 Sat Nov 30 2019 9:10am
I don't think listening helps in this case.
Post #591235 Sat Nov 30 2019 10:58am
andrew kennedy
sensor probem
Thanks for that info!!!. I'll have a look on line to see if I can find a site giving details of how to remove the rear bumper. Regards Andrew Andrew Kennedy
Post #591240 Sat Nov 30 2019 12:38pm
Eaters
Here you go
 Robin
Gone:
MGZTT 190 2.5
Post #591241 Sat Nov 30 2019 1:06pm
andrew kennedy
Parking sensor
Many thanks Robin. The forum is working well!!! Regards from France. Andrew Andrew Kennedy
Post #591377 Mon Dec 02 2019 6:57pm
Duc750
Have a decent can of chassis paint on hand when you remove the rear bumper - its pretty horrible in there sometimes 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #591418 Tue Dec 03 2019 4:24pm
RobP
Almost certainly broken wire on the loom inside the bumper skin TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #591436 Tue Dec 03 2019 10:21pm
andrew kennedy
Rear Sensor problem
Rob, thanks for the input!! When you say 'broken wire in the loom' - after I've taken the bumper off and cleaned the area, should it be relatively simple to find the break? the phrase LOOM conjures up a mass collection of wiring. Andrew Andrew Kennedy
Post #591467 Wed Dec 04 2019 4:21pm
Eaters
I can't speak for RobPs experience but when I took the bumper off mine, it was quite obvious where there was a problem (see the link I posted above where the red wire is just broken). And at this part of the car the "loom" is just a few wires. Nothing complicated. Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #591486 Thu Dec 05 2019 8:22am
andrew kennedy
Rear Sensor problem
Many thanks for all the advice!!!! When it's a warmer day, I will be under the car taking the bumper off to have a good look round! Andrew Andrew Kennedy
Post #591497 Thu Dec 05 2019 1:09pm
do you not have an GAP IID ?
Post #591513 Thu Dec 05 2019 6:53pm
andrew kennedy
Nope...... Andrew Kennedy
Post #591515 Thu Dec 05 2019 8:27pm
RobP
Re: Rear Sensor problem
Dont worry loom means 4 pairs of wires at the thickest part!
Yes mine was very obvious I just followed the wire along where the are cliped to bumper skin and found the break as quite visible and I think broken in same place a per photo in Eaters thread https://www.rrsport.co.uk/forum/topic48459...ng+sensors TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #591517 Thu Dec 05 2019 8:52pm
