Home > In Car Electronics > Rear Sensor problem |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4753 |
it will be one sensor at fault.
Fri Nov 29 2019 2:08pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I believe some find it possible to listen by each sensor and hear which one is not working.
Sat Nov 30 2019 8:10am |
I don't think listening helps in this case. |
Sat Nov 30 2019 9:58am |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 310 |
Thanks for that info!!!. I'll have a look on line to see if I can find a site giving details of how to remove the rear bumper. Regards Andrew Andrew Kennedy |
Sat Nov 30 2019 11:38am |
Here you go
Sat Nov 30 2019 12:06pm |
Many thanks Robin. The forum is working well!!! Regards from France. Andrew Andrew Kennedy |
Mon Dec 02 2019 5:57pm |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
Have a decent can of chassis paint on hand when you remove the rear bumper - its pretty horrible in there sometimes 2012 SDV6 HSE (technically its hers)
Tue Dec 03 2019 3:24pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Almost certainly broken wire on the loom inside the bumper skin TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Tue Dec 03 2019 9:21pm |
Rob, thanks for the input!! When you say 'broken wire in the loom' - after I've taken the bumper off and cleaned the area, should it be relatively simple to find the break? the phrase LOOM conjures up a mass collection of wiring. Andrew Andrew Kennedy |
Wed Dec 04 2019 3:21pm |
I can't speak for RobPs experience but when I took the bumper off mine, it was quite obvious where there was a problem (see the link I posted above where the red wire is just broken). And at this part of the car the "loom" is just a few wires. Nothing complicated. Robin
Thu Dec 05 2019 7:22am |
Many thanks for all the advice!!!! When it's a warmer day, I will be under the car taking the bumper off to have a good look round! Andrew Andrew Kennedy |
Thu Dec 05 2019 12:09pm |
do you not have an GAP IID ? |
Thu Dec 05 2019 5:53pm |
Nope...... Andrew Kennedy |
Thu Dec 05 2019 7:27pm |
Dont worry loom means 4 pairs of wires at the thickest part! Yes mine was very obvious I just followed the wire along where the are cliped to bumper skin and found the break as quite visible and I think broken in same place a per photo in Eaters thread https://www.rrsport.co.uk/forum/topic48459...ng+sensors TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Thu Dec 05 2019 7:52pm |
