![]() | Home > Technical > Engine Oil Level Monitor System Fault |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
At that mileage, probably not. But an oil pressure test before engine removal won't hurt. If the test shows poor pressure, then maybe an inspection of the pump might be a good idea. If the pump looks good, then low(ish) pressure might be the sign of something else like leaking lifters, bearing wear or even a blockage. However, i'd be surprised if you had any problems at that mileage. Joe |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 269 ![]() ![]() |
Just following up on the original post. Diagnosis didn't show anything, not even an error code.
I started this thread so hopefully here is a final (touch wood) update.
Sitchey Member Since: 11 Jul 2021 Location: Armagh Posts: 11 ![]() ![]() |
Hi
