Home > Technical > Engine Oil Level Monitor System Fault |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 |
At that mileage, probably not. But an oil pressure test before engine removal won't hurt. If the test shows poor pressure, then maybe an inspection of the pump might be a good idea. If the pump looks good, then low(ish) pressure might be the sign of something else like leaking lifters, bearing wear or even a blockage. However, i'd be surprised if you had any problems at that mileage. Joe |
Fri Sep 04 2020 12:16pm |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 225 |
Just following up on the original post. Diagnosis didn't show anything, not even an error code.
Tue Sep 08 2020 12:36pm |
I started this thread so hopefully here is a final (touch wood) update.
Mon Sep 21 2020 6:11pm |
