Home > General > My 2007 RRS |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 918 |
Par for the course a lot of the jobs,, the perils of RR ownership. One job I would address straight away is the handbrake if you are having issues, if it decides to go south it could cost you in excess of a grand if you are unlucky whereas if you spend less than a £100 now and have the rear shoes cleaned and set correctly you could avoid a hefty bill. 2010 RRS, TDV8
Fri Aug 09 2019 4:40pm |
IWC1 Member Since: 15 Jul 2019 Location: Suffolk Posts: 20 |
Thanks for the advice, I appreciate it.
Mon Aug 12 2019 8:34am |
So all the work has been completed
Sun Sep 01 2019 10:38pm |
I meant to add,
Sun Sep 01 2019 10:46pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Andy - seriously no need for the switch... https://www.rrsport.co.uk/forum/topic43444.html |
Mon Sep 02 2019 7:52pm |
Ah, thanks for that, Even I can do that!
Mon Sep 02 2019 8:01pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1848 |
w Double locking? 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Mon Sep 02 2019 9:32pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
Yes familer.
Tue Sep 03 2019 3:47am |
Yes, click the remote once, 3 flashes then click once more, another 3 flashes and then the drivers door is locked. Andy |
Tue Sep 03 2019 9:52am |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 |
From all locked, Does all doors open with 1 press only? |
Tue Sep 03 2019 7:24pm |
No, 1 unlock just unlocks the drivers door.
Wed Sep 04 2019 3:44pm |
Maybe read the handbook - could it be this?
Wed Sep 04 2019 8:30pm |
Thanks for the suggestion, but I should have stated that I have already referred to the owners manual when I first experienced this issue.
Thu Sep 05 2019 8:18pm |
Oh, forgot to mention the good news....it passed its MOT today!
Thu Sep 05 2019 8:21pm |
