Home > General > My 2007 RRS
IWC1
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
My 2007 RRS
So the fun begins....Finally took possession of the car two weeks ago, but as Ive been away on business trips, I left the wife to 'introduce herself to the car and log any issues'....
So far, its going to need front bottom arms,+ replacement bolts, CV boots, OSR brake pipe, rear track control arms.
Sticking handbrake issue, 4 x 4 tracking and alignment, central locking sluggish and intermittent.
All the usual issues Rolling Eyes
But what a car! Mr. Green
Im holding off posting pics until its sorted.
A great weekend to all.
Andy
Post #585115 Fri Aug 09 2019 10:16am
gogsy1956
Par for the course a lot of the jobs,, the perils of RR ownership. One job I would address straight away is the handbrake if you are having issues, if it decides to go south it could cost you in excess of a grand if you are unlucky whereas if you spend less than a £100 now and have the rear shoes cleaned and set correctly you could avoid a hefty bill. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #585131 Fri Aug 09 2019 4:40pm
IWC1
Thanks for the advice, I appreciate it.
Its going in today for the repairs, so I will make sure they address this first.
Looking forward to driving it all fixed up.
Andy
Post #585228 Mon Aug 12 2019 8:34am
IWC1
So all the work has been completed
- lower front arms, bushes, gators, sump, Oil change + coolant and they said upper rear O/S arm was OK, except the Handbrake issue, which my son ( a mechanic), sorted out this weekend, by completely stripping down both the rear and front brakes, inspecting, re-setting up the rear EPB shoes and a total clean up and re-grease, showing me that pads, disc, and shoe linings were really good.
It seems the previous owner had just let the RRS sit for the last six months..
The handbrake functions perfectly well now, and is really quick to hold and release, no more bongs and handbrake warnings.
I still have a slight wobble on braking, (much less), and there are now 4 x new Uniroyal Rain sport tyres fitted, balanced and weighted, so going to look at new discs too, although then existing ones looked good, but COULD be slightly warped.
Next up is an MOT a month in advance this week, then a full alignment and my son said he will go further and take a good look at the front hubs, as he didn't take the discs off on the first inspection on the front, so maybe a change to new front hubs and discs upcoming.
Ive just had the apparently common 'Bonnet open' message, so cleaned the catches and hooks today which were totally gummed up and will order a new sensor/switch this week.
The message has gone, but when my wife started her car next to the RRS, the alarm went off, so I am assuming to start with this is the bonnet issue.
(Sigh), its been a hard and expensive intro to RRS ownership, but I love the car, feels such a great place to sit and drive from, each repair makes it feel like it is slowly coming back....
Andy
Post #586224 Sun Sep 01 2019 10:38pm
IWC1
I meant to add,
Ref the sluggish central locking, it all works, except if I lock it with just one click of the remote, it locks. (except the drivers door), but then I if I lock it second time, it locks all and secure.
Does this seem familiar to anybody else and i so, how to fix?
(I'm guessing a new Latch system).
This forum is great!
Andy
Post #586225 Sun Sep 01 2019 10:46pm
Pufftmw
Andy - seriously no need for the switch...
https://www.rrsport.co.uk/forum/topic43444.html
Post #586253 Mon Sep 02 2019 7:52pm
IWC1
Ah, thanks for that, Even I can do that!
I'll pull it out as our your very clear description and photos and follow through with cleaning it up.
Cheers-much appreciated Thumbs Up
Andy
Post #586254 Mon Sep 02 2019 8:01pm
Brit Plumber
IWC1 wrote:
I meant to add,
Andy
w
Double locking? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #586257 Mon Sep 02 2019 9:32pm
Yes familer.
Motor getting lazy.
Replace latch assembly
Post #586266 Tue Sep 03 2019 3:47am
IWC1
Brit Plumber wrote:
IWC1 wrote:
I meant to add,
Andy
w
Double locking?
Yes, click the remote once, 3 flashes then click once more, another 3 flashes and then the drivers door is locked.
Andy
Post #586271 Tue Sep 03 2019 9:52am
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
From all locked, Does all doors open with 1 press only?
Post #586302 Tue Sep 03 2019 7:24pm
IWC1
No, 1 unlock just unlocks the drivers door.
Andy
Post #586336 Wed Sep 04 2019 3:44pm
rover75
Maybe read the handbook - could it be this?
Single-point entry
This is a personal security feature, which enables only the driver’s door to be unlocked,
leaving the other doors in a locked state.
Single-point entry can be disabled on individual remote control keys by pressing and holding the lock and unlock buttons together for three seconds.
Repeating the procedure will re-enable the feature.
Each time single-point entry is turned on or off, the vehicle will lock then unlock into the selected mode (all doors unlocked or just the driver’s door unlocked)
Post #586360 Wed Sep 04 2019 8:30pm
IWC1
Thanks for the suggestion, but I should have stated that I have already referred to the owners manual when I first experienced this issue.
Doesn't make any difference to the problem.
Thanks again
Andy
Post #586423 Thu Sep 05 2019 8:18pm
IWC1
Oh, forgot to mention the good news....it passed its MOT today! Very Happy
Andy
Post #586424 Thu Sep 05 2019 8:21pm
