![]() | Home > General > My 2007 RRS |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
Par for the course a lot of the jobs,, the perils of RR ownership. One job I would address straight away is the handbrake if you are having issues, if it decides to go south it could cost you in excess of a grand if you are unlucky whereas if you spend less than a £100 now and have the rear shoes cleaned and set correctly you could avoid a hefty bill. 2010 RRS, TDV8
IWC1 Member Since: 15 Jul 2019 Location: Suffolk Posts: 20 ![]() ![]() ![]() |
Thanks for the advice, I appreciate it.
So all the work has been completed
I meant to add,
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Andy - seriously no need for the switch... https://www.rrsport.co.uk/forum/topic43444.html |
Ah, thanks for that, Even I can do that!
w Double locking? 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
Yes familer.
Yes, click the remote once, 3 flashes then click once more, another 3 flashes and then the drivers door is locked. Andy |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
From all locked, Does all doors open with 1 press only? |
No, 1 unlock just unlocks the drivers door.
Maybe read the handbook - could it be this?
Thanks for the suggestion, but I should have stated that I have already referred to the owners manual when I first experienced this issue.
Oh, forgot to mention the good news....it passed its MOT today! |
