Home > Technical > mass air flow sensor
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. I would be grateful if anyone could point me to a web site showing how to locate and clean the mass air flow sensor. I have surfed the net and cannot find a suitable site. Andrew Kennedy
Post #584907 Sat Aug 03 2019 1:07pm
The thing on the air flow box.
But I would leave alone
People usually say clean the MAP sensor
Which is the small sensor in the Y. Air inlet in middle of engine.
Post #584918 Sat Aug 03 2019 7:19pm
andrew kennedy
Thanks for yours Andy!! Researching the problem I am getting it just might just be the Mass-air-flow-sensor that needs a clean. I'v purchased the spray for the job, but before proceeding I am hoping someone out there might be able to send me a picture or better still point me in the direction of a Video as to exactly where the sensor is and how to proceed. Andrew Kennedy
Post #584948 Sun Aug 04 2019 1:19pm
Well on top of the airbox is a
Large jubilee clip.
You loosen this
And the two bolt securing the pipe.
The pipe can then Be moved to the side.
You can then see into the air Meter.
Post #584959 Sun Aug 04 2019 7:08pm
andrew kennedy
Many thanks Andy!! Andrew Kennedy
Post #584966 Sun Aug 04 2019 7:48pm
andrew kennedy
Andy - after I take out the tube in which the Mass Air Flow Sensor is located, I presume there is no reason why I shouldn't remove the sensor from the tube to clean it??! In fact do I need to take the tube out, cant I simple disconnect the electrics and remove the sensor?!? Andrew Kennedy
Post #584987 Mon Aug 05 2019 1:07pm
not sure.
I haven't tried.
They are fragile items though
Post #584994 Mon Aug 05 2019 6:18pm
gogsy1956
As Andy has already mentioned, when you disconnect the hose(s), you will be able to see the sensor inside the box,,, you will also notice how delicate they are,, basically a thin wire with a resistance in the centre. Last thing you want to do is start poking them, I don't think they tend to get dirty at all so no need to clean, if they are a problem no other option but to replace. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #584995 Mon Aug 05 2019 6:29pm
Bardley
Cleaning rarely if ever, sorts a problem with the MAF unit.
Have you read the outputs at different revs and loads? This is the usual route to diagnose a fault. The sensor, being in the engine side of the airbox and fed clean air, does not require cleaning. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #585005 Mon Aug 05 2019 10:56pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
As has been said above, cleaning never made any difference to mine either, but a new one sorted it. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #585025 Tue Aug 06 2019 1:41pm
rover75
Denmark 2007 Range Rover Sport Supercharged Stornoway Grey
10 years ago one of my previous RR was successfully treated with maf cleaner sprayed onto it, so maybe it's one in a million it helps, new is advised if faulty as very sensitive. But of course be sure it's actually faulty before you make it faulty Very Happy
Post #585035 Tue Aug 06 2019 6:40pm
