| RRSPORT.CO.UK | ||
|  | Home > Technical > mass air flow sensor |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | The thing on the air flow box.
|  Sat Aug 03 2019 6:19pm |
| andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 348      |
 Thanks for yours Andy!! Researching the problem I am getting it just might just be the Mass-air-flow-sensor that needs a clean. I'v purchased the spray for the job, but before proceeding I am hoping someone out there might be able to send me a picture or better still point me in the direction of a Video as to exactly where the sensor is and how to proceed. Andrew Kennedy | ||
|  Sun Aug 04 2019 12:19pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Well on top of the airbox is a
|  Sun Aug 04 2019 6:08pm |
 Many thanks Andy!! Andrew Kennedy | ||
|  Sun Aug 04 2019 6:48pm |
 Andy - after I take out the tube in which the Mass Air Flow Sensor is located, I presume there is no reason why I shouldn't remove the sensor from the tube to clean it??! In fact do I need to take the tube out, cant I simple disconnect the electrics and remove the sensor?!? Andrew Kennedy | ||
|  Mon Aug 05 2019 12:07pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | not sure.
|  Mon Aug 05 2019 5:18pm |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | As Andy has already mentioned, when you disconnect the hose(s), you will be able to see the sensor inside the box,,, you will also notice how delicate they are,, basically a thin wire with a resistance in the centre. Last thing you want to do is start poking them, I don't think they tend to get dirty at all so no need to clean, if they are a problem no other  option but to replace. 2010 RRS, TDV8
|  Mon Aug 05 2019 5:29pm |
| Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150    | Cleaning rarely if ever, sorts a problem with the MAF unit.
|  Mon Aug 05 2019 9:56pm |
| insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533      | As has been said above, cleaning never made any difference to mine either, but a new one sorted it. 13MY Range Rover Sport Autobiography SDV6 - mine
|  Tue Aug 06 2019 12:41pm |
| rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109      | 10 years ago one of my previous RR was successfully  treated with maf cleaner sprayed onto it, so maybe it's one in a million it helps, new is advised if faulty as very sensitive. But of course be sure it's actually faulty before you make it faulty  | ||
|  Tue Aug 06 2019 5:40pm |
| Posting Rules
