![]() | Home > Technical > mass air flow sensor |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5143
The thing on the air flow box.
| andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 348
Thanks for yours Andy!! Researching the problem I am getting it just might just be the Mass-air-flow-sensor that needs a clean. I'v purchased the spray for the job, but before proceeding I am hoping someone out there might be able to send me a picture or better still point me in the direction of a Video as to exactly where the sensor is and how to proceed. Andrew Kennedy |
Well on top of the airbox is a
Many thanks Andy!! Andrew Kennedy |
Andy - after I take out the tube in which the Mass Air Flow Sensor is located, I presume there is no reason why I shouldn't remove the sensor from the tube to clean it??! In fact do I need to take the tube out, cant I simple disconnect the electrics and remove the sensor?!? Andrew Kennedy |
not sure.
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
As Andy has already mentioned, when you disconnect the hose(s), you will be able to see the sensor inside the box,,, you will also notice how delicate they are,, basically a thin wire with a resistance in the centre. Last thing you want to do is start poking them, I don't think they tend to get dirty at all so no need to clean, if they are a problem no other option but to replace. 2010 RRS, TDV8
| Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150
Cleaning rarely if ever, sorts a problem with the MAF unit.
| insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533
As has been said above, cleaning never made any difference to mine either, but a new one sorted it. 13MY Range Rover Sport Autobiography SDV6 - mine
| rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109
10 years ago one of my previous RR was successfully treated with maf cleaner sprayed onto it, so maybe it's one in a million it helps, new is advised if faulty as very sensitive. But of course be sure it's actually faulty before you make it faulty |
| All times are GMT |
