![]() | Home > Faults & Fixes > White smoke on startup with 2010 RRS |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9082 ![]() ![]() ![]() |
Presumably the PCV oil separator was letting some oil through in to the engine air inlet and that was burning off when starting. 2012 SDV6 - it's missing a couple of cylinders
LYONS1 Member Since: 12 Jun 2019 Location: cape town Posts: 10 ![]() ![]() ![]() |
Yes, that is correct |
Lex007 Member Since: 11 Jun 2020 Location: London Posts: 1 ![]() ![]() ![]() |
Hello Lyons or anyone else that maybe able to help. Do you have any advice on doing this job I think I have the same problem, have noticed oil from the crankcase on drivers side and now have reduced performance car changing gears before 2000 revs.
