Home > Faults & Fixes > White smoke on startup with 2010 RRS
LYONS1
South Africa 2010 Range Rover Sport Supercharged Santorini Black
I had White smoke on startup and rough idling on 2010 RRS SC. Mileage 172000 km.
It was fixed by replacing the PCV valve. To replace the PCV valve you will have to replace the complete tappet cover, it is build into it. Not sure why they do that, because I took the old one apart and noticed that it was only 2 rubber diaphragms that were halfway torn.
Strangely, the White smoke on startup only started after I took it for a service at the dealer. I was confused and thought they broke something, but I suppose it was the new oil starting it.
The other symptom of a faulty PCV valve, you hear a air whistling noise when idling and shutting down.
Hope this can help someone in the future.
Regards
JL
Post #582256 Wed Jun 12 2019 2:29pm
Presumably the PCV oil separator was letting some oil through in to the engine air inlet and that was burning off when starting. 2012 SDV6 - it's missing a couple of cylinders
Post #582262 Wed Jun 12 2019 3:27pm
LYONS1
Yes, that is correct
Post #582266 Wed Jun 12 2019 5:13pm
Lex007
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hello Lyons or anyone else that maybe able to help. Do you have any advice on doing this job I think I have the same problem, have noticed oil from the crankcase on drivers side and now have reduced performance car changing gears before 2000 revs.
Thanks for any advice in advance.
Post #600090 Thu Jun 11 2020 4:38pm
