![]() | Home > General > Air con regas |
woodsie Member Since: 23 Nov 2015 Location: Milton Keynes Posts: 67 ![]() ![]() ![]() |
Air con is blowing cool but not as cold as it should be. My indie is stacked out with work so can’t check it out/ regas for some time.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5126 ![]() ![]() ![]() |
think I would wait for your indi to be free.
Find a local air con specialist who has nitrogen to test the system first as i have found the vacuum test is not that good a test.As the first part of the test is to see if it holds a vacuum but the pressure can actually seal the hole and makes it seem like the system is all ok when in fact there can be a hole i had this on a few cars but if they put nitrogen in it will leak out if there is a hole so far better |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2022 ![]() ![]() |
I’ve found a local air con specialist to do just this job |
Thanks for all your replies.
