Home > General > Air con regas
woodsie
United Kingdom 2010 Range Rover Sport Supercharged Autobiography Stornoway Grey
Air con regas
Air con is blowing cool but not as cold as it should be. My indie is stacked out with work so can’t check it out/ regas for some time.
Anyone had experience of Halfrauds/ Kwiknick etc or can recommend anyone else in the MK area.
Chris.
Post #581081 Sun May 19 2019 1:18pm
riverblanche
had our Mini done at a place called Lodge tyres, may not have a branch near you but think they all work the same way
The machine goes through a cycle and will not proceed if it fails the first test
pressure test first
vac out and maintain for set time
refill with correct amount (dialed in by man at the start)
may get another pressure test at the end?
About a year ago I paid £35 but the gas has risen in price and it depends what price they last bought at Question Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #581090 Sun May 19 2019 3:44pm
think I would wait for your indi to be free.
Kwikfit just use an automatic machine, and you could end up with a worse position.
Post #581091 Sun May 19 2019 4:04pm
geoffsnook
Find a local air con specialist who has nitrogen to test the system first as i have found the vacuum test is not that good a test.As the first part of the test is to see if it holds a vacuum but the pressure can actually seal the hole and makes it seem like the system is all ok when in fact there can be a hole i had this on a few cars but if they put nitrogen in it will leak out if there is a hole so far better Thumbs Up
Post #581097 Sun May 19 2019 7:25pm
DrRob
I’ve found a local air con specialist to do just this job Thumbs Up
http://www.avacs.co.uk/aircon_servicing.html * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #581101 Sun May 19 2019 8:28pm
woodsie
Thanks for all your replies.
Waited for my indie to slot me in and all now sorted.
Cheers Cool
Post #581740 Sat Jun 01 2019 3:52pm
