![]() | Home > Technical > Ctek Comfort Connector 7pin Charging Adaptor |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
Also look at the Optimate range...very good product and used alot by motorcyclists. I have a few bikes left on thrm permanently.
You'll need the Auxiliary socket, and the car battery can be charged thro' the Permanent live. 2011 MY D4 HSE
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
I have a MXS5 and a MXS10 both work fine, the MXS10 has a larger capacity and has a 12V supply option.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5136 ![]() ![]() ![]() |
Don't even need to bend down to plug it in, yet alone take towing eye cover off.
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 ![]() ![]() ![]() |
^^Looks great.... |
As the vehicle has a BMS system fitted you need to use the Pos. battery terminal and a body earth point not the neg. terminal, there are some close to the battery. I also connected it via a Anderson plug so I can unplug it and plug in my battery charger or portable compressor if needed.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
Take a look at the site shop
