Home > Technical > Ctek Comfort Connector 7pin Charging Adaptor
Buster007
I’m looking to get a Ctek Battery Conditioner for my 2012 RRS L320 which one do i need and can I also use it on my 2010 Defender 90 2.4? How do I connect to the RRS? Should I get trailer socket fitted like the one pictured below on my Defender?
 Cheers Laurence.
Post #573023 Sun Jan 13 2019 7:51pm
Bardley
Also look at the Optimate range...very good product and used alot by motorcyclists. I have a few bikes left on thrm permanently.
https://www.optimate.co.uk/ 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #573025 Sun Jan 13 2019 7:59pm
Bardley
You'll need the Auxiliary socket, and the car battery can be charged thro' the Permanent live. 2011 MY D4 HSE
Post #573026 Sun Jan 13 2019 8:01pm
TubaPlayer
I have a MXS5 and a MXS10 both work fine, the MXS10 has a larger capacity and has a 12V supply option.
You will either need a grey 12S (caravan) socket or the 13 pin socket to connect to if you want to use a trailer socket.
The other option is to fit a comfort adaptor some where suitably hidden to just plug the CTEK into. 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #573030 Sun Jan 13 2019 8:32pm
Don't even need to bend down to plug it in, yet alone take towing eye cover off.
Post #573031 Sun Jan 13 2019 8:54pm
Buster007
^^Looks great.... Thumbs Up Where is it plugged in to...??^^ Whistle
Just worked it out... Rolling with laughter Rolling with laughter
Is it directly in to the battery? Cheers Laurence.
Post #573033 Sun Jan 13 2019 9:43pm
As the vehicle has a BMS system fitted you need to use the Pos. battery terminal and a body earth point not the neg. terminal, there are some close to the battery. I also connected it via a Anderson plug so I can unplug it and plug in my battery charger or portable compressor if needed.
Post #573035 Sun Jan 13 2019 9:58pm
shepp
Take a look at the site shop
https://www.disco3.co.uk/shop/tow-electric...c-p45.html
I purchased the 13pin and use it with a mxs10.
Due to not doing many miles and the wife liking the car warm (pre heat).
I charge the car overnight once every week.
 MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #573038 Sun Jan 13 2019 10:56pm
