Home > Maintenance & Modifications > Loose coupling
Thumbs Up Just let me know how you get on as may have to do it myself one day, but at least I have the bit's. Rolling with laughter
Post #553391 Sat Apr 07 2018 9:14am
tinybum
Hi col
I had a reply from powerhouse and have to say they have given me what I call a good quote apparently they are still saying that the supercharger has to come out but will do a snout rebuild change the oil and coupling all for £700
Post #553940 Thu Apr 12 2018 7:37pm
Sounds reasonable quote if that's all in price, as you say have read it can be done in situ. some say not, did read it can be done in position on Range Rover but not if engine fitted to a Jag due to a lot less access. Time will tell I guess, just post results when it's done. Thumbs Up
Post #553949 Thu Apr 12 2018 9:20pm
tinybum
No problem
Post #553950 Thu Apr 12 2018 9:31pm
geoffsnook
I am about to change this part myself so i assume its the serpentine belt off with the plastic inlet pipes and then the 7 bolts sounds easy enough to do just got my coupler from the states Thumbs Up
Post #558034 Sun Jun 03 2018 10:25am
tinybum
Hi I have been told that the supercharger needs to come out on the 2010 5 litre engine as there is no room to do the job with the engine in place so while it is out it will have a snout rebuild a oil change as the drain plug is at the back of the supercharger and the coupler change
Post #558035 Sun Jun 03 2018 10:47am
geoffsnook
Mine is the 4.2 so i think i should be able yo do it in place Thumbs Up
Post #558036 Sun Jun 03 2018 10:55am
tinybum
Yeah my understanding is that the 4.2 can be done a lot easier than mine
Post #558038 Sun Jun 03 2018 11:00am
