![]() | Home > General > Engine top end strip down |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
OK, so my local Pug dealer will sell an oil pump (1001G2) for £131.00. I got this part number from another post, is this the correct one?
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5121 ![]() ![]() ![]() |
I guess you could take the old one or broken one with you, to make sure the mating face to the engine is the same |
Cheers Andy... yes was planning on doing that anyways just to make doubly sure it was same as old one, well apart from having the new 'strengthened' web part on it.
U got the 2nd head off then ? |
Not yet, I bought a pair of heads as I was getting the impression that no doubt there would be damage (anything from minor to major damage) to the RH side head also. So just decided to get the pair at the same time. If no damage to the RH side, when I get it off then great, 'won a watch' I can then sell the RH head on again. RRS 2.7 HSE Stornoway Grey
Got replacement head LH side on bench now ready (I think) to put on car. So, best way to go about this would be.....?
Check all the threaded holes are clear. Wind bolts in all the way.
Thanks Andy. I will be using your points as reference as I go.
The HGaskets aren't handed.
OK thanks.
Got the head on eventually (without cams as yet, that's one of the next jobs), exhaust manifold gasket and studs are back on. Next will be putting on the EGR valve then it should be the cams and HPFP including cover. RRS 2.7 HSE Stornoway Grey
Is this torque for HPFP rear cam bolt DM? RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4524 ![]() ![]() ![]() |
Yes |
OK thanks Mikey RRS 2.7 HSE Stornoway Grey
