![]() | Home > Maintenance & Modifications > ctek comfort connect lead |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 ![]() ![]() |
I have hard wired mine in the boot fuse box and exposed the connector at the bottom of trim panel. CTEK have a variety of accessories including a panel that can be mounted on the front grill for example. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
yeah charging from the front grill or rear end would be my preference due to how i have to park on the drive but i don't really want it on show to much ? |
I park with the car's rear towards the house. The charger and extension reel stay in the boot. CTEK's own mains lead was just a few inches short to reach my external wall socket so have to use extension. The only visible bit is the cable emerging at the bottom of the boot lid and going into the socket.
yeah i don't have tow electrics either which is a shame, do you have any pics of your setup ? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5134 ![]() ![]() ![]() |
Me too |
I had the LR branded CTek conditioner fitted to my last Evoque through the front grille (again because of the way round I park the car on the drive - if I back up the drive then the rear of the car is shaded from cellular phone network signals and the InControl Secure functions don't work without a good mobile signal so I have no remote monitoring facility). The connector was all but invisible in the black plastic of the grille. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I do from my old setup when I was jumping a relay to make the boot socket live to charge via that. Since then I have hardwired a comfort connector and ditched the cigarette lighter connector that I was using before. Didn't take any pictures after that but it was as simple as connecting the black cable to car's body for earth and the red cable (via a fuse piggyback) to a fuse that was permanent live for example trailer battery. Having said that, the power socket in the boot is another charging option so you can still check out step 11 in this guide from my old setup: http://www.rrsport.co.uk/forum/post473608.html#473608 The only downside is that jumping the relay *may* record a harmless fault code every time the car is started but you will never know unless you plug in a fault code reader. However, the fuse layout changed in MY16 so this will only help if you have the same model car as me. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
[URL=] |
think i need to get tow bar electrics fitted to make life easier haha |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
If you haven't ordered the Ctek yet, this company are including the Comfort Indicator with Battery Condition Indicator free:
Yes that ebay auction is good value.
Don't actually need it. See my picture above. Last edited by Andy K on Sun Jan 15 2017 1:08pm. Edited 1 time in total |
i already have the charger and quick connect lead was just wondering how else people connected theres as i would like to just be able to connect quick without moving the car around and lifting the bonnet every time but thank you anyway |
i will have to have a look at doing that Andy doesn't look to hard to do |
Yes, I know, I just posted that for the benefit of anyone following your lead (no pun intended!) |
