Home > Maintenance & Modifications > ctek comfort connect lead
Wayneclarke
I've got a ctek charger with the comfort lead connected to the battery for quick connect, i was just wondering where you guys have mounted your leads?? somewhere i don't have to keep opening the bonnet would be nice?
Post #514504 Sun Jan 15 2017 8:21am
fkarim
I have hard wired mine in the boot fuse box and exposed the connector at the bottom of trim panel. CTEK have a variety of accessories including a panel that can be mounted on the front grill for example. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #514507 Sun Jan 15 2017 8:27am
Wayneclarke
yeah charging from the front grill or rear end would be my preference due to how i have to park on the drive but i don't really want it on show to much ?
Post #514509 Sun Jan 15 2017 8:31am
fkarim
I park with the car's rear towards the house. The charger and extension reel stay in the boot. CTEK's own mains lead was just a few inches short to reach my external wall socket so have to use extension. The only visible bit is the cable emerging at the bottom of the boot lid and going into the socket.
If you have towbar electrics (I don't) then there is an adapter available on disco3 site. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #514510 Sun Jan 15 2017 8:44am
Wayneclarke
yeah i don't have tow electrics either which is a shame, do you have any pics of your setup ?
Post #514511 Sun Jan 15 2017 8:50am
Me too
Post #514514 Sun Jan 15 2017 9:43am
Tim in Scotland
I had the LR branded CTek conditioner fitted to my last Evoque through the front grille (again because of the way round I park the car on the drive - if I back up the drive then the rear of the car is shaded from cellular phone network signals and the InControl Secure functions don't work without a good mobile signal so I have no remote monitoring facility). The connector was all but invisible in the black plastic of the grille. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #514515 Sun Jan 15 2017 9:47am
fkarim
I do from my old setup when I was jumping a relay to make the boot socket live to charge via that. Since then I have hardwired a comfort connector and ditched the cigarette lighter connector that I was using before. Didn't take any pictures after that but it was as simple as connecting the black cable to car's body for earth and the red cable (via a fuse piggyback) to a fuse that was permanent live for example trailer battery.
Having said that, the power socket in the boot is another charging option so you can still check out step 11 in this guide from my old setup: http://www.rrsport.co.uk/forum/post473608.html#473608 The only downside is that jumping the relay *may* record a harmless fault code every time the car is started but you will never know unless you plug in a fault code reader.
However, the fuse layout changed in MY16 so this will only help if you have the same model car as me. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #514520 Sun Jan 15 2017 10:46am
[URL=]
[/[URL=]
[/URL]
This is a ctek lead with indicator which are slightly longer and suitable for the RRS.
Can be purchased on eBay for £5. (M8 version)
Connected to the towbar power supply.
[URL=]
[/URL]
On an early RRS1
I have soldered the red wire to the green wire with brown stripe and put red tape around. (don't need the towing electrics
fitted) (see grey plug in picture)
The black ring to a bolt (lower left of picture)
Post #514539 Sun Jan 15 2017 12:36pm
Wayneclarke
think i need to get tow bar electrics fitted to make life easier haha
Post #514541 Sun Jan 15 2017 12:44pm
donny dog
If you haven't ordered the Ctek yet, this company are including the Comfort Indicator with Battery Condition Indicator free:
http://www.ebay.co.uk/itm/160927753460
Post #514542 Sun Jan 15 2017 12:49pm
Yes that ebay auction is good value.
Don't actually need it. See my picture above.
Post #514544 Sun Jan 15 2017 1:05pm
Wayneclarke
i already have the charger and quick connect lead was just wondering how else people connected theres as i would like to just be able to connect quick without moving the car around and lifting the bonnet every time but thank you anyway
Post #514545 Sun Jan 15 2017 1:06pm
Wayneclarke
i will have to have a look at doing that Andy doesn't look to hard to do
Post #514546 Sun Jan 15 2017 1:09pm
donny dog
Yes, I know, I just posted that for the benefit of anyone following your lead (no pun intended!)
Post #514547 Sun Jan 15 2017 1:15pm
