Home > Technical > Timing belt - I've obviously messed up :-(
tanloverluke
Well my timing belt change has gonne horribly wrong and I haven't a clue why. The rear belt was a doddle, then I came to the front belt and I can't rotate the engine now. I am now in need of a good mechanic, somewhere near to Honiton where I live, so even if you're based as far as Exeter, Taunton, Yeovil or Dorchester can an experienced RRS mechanic come and visit me? Obviously I can't take her off the drive now, she's stuck Big Cry
I'm never touching another car, ever again. Time to call in a pro! Please help! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #513865 Sun Jan 08 2017 6:02pm
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
CAM shaft and crank shaft has gone out of sync, what if you get access to workshop manual on TOPIX for 24 hours for (£9)your model year and use it to get everting in sync.
Post #513866 Sun Jan 08 2017 6:14pm
DrRob
Try contacting Woody32 who is mobile and based in Taunton perhaps????
http://www.disco3.co.uk/forum/member-woody32.html * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #513868 Sun Jan 08 2017 6:34pm
It's maybe worth posting pics of the belt etc
I take it you didn't get as far as starting it ?
Post #513874 Sun Jan 08 2017 7:22pm
tanloverluke
Thanks gents. udash I would have probably tried that a year or so ago, but the amount of bad luck I've experienced lately makes me very wary of trying anything new. But thanks anyway.
I'll give Woody32 a go, thanks DrRob.
I followed the How-To section meticulously, I still can't see where I went wrong. Absolutely nothing moved, markings were still in their exact places after installing the new belt. Fed up Evil or Very Mad Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #513890 Sun Jan 08 2017 9:54pm
garrycol
Australia
You have removed the locking pins?? 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #513913 Mon Jan 09 2017 5:47am
tanloverluke
oh yes, locking pins removed Thumbs Up Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #513962 Mon Jan 09 2017 6:48pm
flack
Did you slacken off both cam belt pulleys, and if so did you tighten them again..if you had the pins in and you did not move the crank then it should have been ok.
Flack Thumbs Up
Post #514163 Wed Jan 11 2017 8:19pm
tanloverluke
Update
After several months off the road, looking sad, she's finally up and running again! I have to say thank you to all of you that have tried to help by giving suggestions but this job was obviously too difficult for me, plus breaking a rib didn't help in my DIY efforts. I therefore employed the services of Kris, aka "Woody" from the Disco forum and this guy is phenomenal. My timing was way out and within a few hours he had everything resolved. Whatsmore he's an incredibly friendly, mild mannered chap. He has since helped me iron out an array of issues, all arising from not having used the car for half a year, such as a sticky turbo actuator and fault codes galore. Now I understand why people recommended him.
A message to anyone wanting to do the front timing belt themselves...think twice! And if you're in the South West, ring Woody! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #523255 Tue Apr 11 2017 8:00am
Black Bess
Good to hear that you are running again. Well done Woody!
Would love to see some pics of your pimp-my-ride project.
Adam..
Post #523263 Tue Apr 11 2017 10:47am
garrycol
Australia
Great stuff but how did you manage to get the timing so far out - not really possible if the cam and crank pins are used. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #523272 Tue Apr 11 2017 11:36am
tanloverluke
garrycol I have no idea, the crankshaft didn't move, instead even with the pins in place the camshaft pulleys moved. Headscratcher!
pictures up as soon as car detailed Thumbs Up Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #523286 Tue Apr 11 2017 2:16pm
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
I'm intrigued, do you think maybe the cam pins could have possibly not been quite in right the way through? , they are a riggle ?
Post #523340 Tue Apr 11 2017 8:48pm
tanloverluke
That was definitely the issue, I simply inserted the pins and assumed that they were in the correct holes. I must admit that I was more concerned about the crankshaft moving, because everyone was telling me that if it moves I'll have problems, so I probably focused less on the camshaft pins. I would not do this again, once bitten twice shy! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #523349 Tue Apr 11 2017 9:50pm
m3nutter
I had big issue with crank lock and it actually came out when tightening the crank nut so I bolted it through starter hole . When is finished I couldn't get it out !
I'm hoping not to have to do that bit again Laughing
Post #523378 Wed Apr 12 2017 5:38am
