![]() | Home > Technical > Timing belt - I've obviously messed up :-( |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
Well my timing belt change has gonne horribly wrong and I haven't a clue why. The rear belt was a doddle, then I came to the front belt and I can't rotate the engine now. I am now in need of a good mechanic, somewhere near to Honiton where I live, so even if you're based as far as Exeter, Taunton, Yeovil or Dorchester can an experienced RRS mechanic come and visit me? Obviously I can't take her off the drive now, she's stuck |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2021 ![]() ![]() |
Try contacting Woody32 who is mobile and based in Taunton perhaps????
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5120 ![]() ![]() ![]() |
It's maybe worth posting pics of the belt etc
Thanks gents. udash I would have probably tried that a year or so ago, but the amount of bad luck I've experienced lately makes me very wary of trying anything new. But thanks anyway.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
You have removed the locking pins?? 07MY RRS TDV6
oh yes, locking pins removed |
Did you slacken off both cam belt pulleys, and if so did you tighten them again..if you had the pins in and you did not move the crank then it should have been ok.
After several months off the road, looking sad, she's finally up and running again! I have to say thank you to all of you that have tried to help by giving suggestions but this job was obviously too difficult for me, plus breaking a rib didn't help in my DIY efforts. I therefore employed the services of Kris, aka "Woody" from the Disco forum and this guy is phenomenal. My timing was way out and within a few hours he had everything resolved. Whatsmore he's an incredibly friendly, mild mannered chap. He has since helped me iron out an array of issues, all arising from not having used the car for half a year, such as a sticky turbo actuator and fault codes galore. Now I understand why people recommended him.
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Good to hear that you are running again. Well done Woody!
Great stuff but how did you manage to get the timing so far out - not really possible if the cam and crank pins are used. 07MY RRS TDV6
garrycol I have no idea, the crankshaft didn't move, instead even with the pins in place the camshaft pulleys moved. Headscratcher!
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 ![]() ![]() ![]() |
I'm intrigued, do you think maybe the cam pins could have possibly not been quite in right the way through? , they are a riggle ? |
That was definitely the issue, I simply inserted the pins and assumed that they were in the correct holes. I must admit that I was more concerned about the crankshaft moving, because everyone was telling me that if it moves I'll have problems, so I probably focused less on the camshaft pins. I would not do this again, once bitten twice shy! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
I had big issue with crank lock and it actually came out when tightening the crank nut so I bolted it through starter hole . When is finished I couldn't get it out !
