![]() | Home > General > SOLAR BATTERY charger - do they work? |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162
Have you let the car go fully to sleep to make sure it stays live all the time. I thought they were Ign switched, but it could be 'car awake' switched I guess?
| SimonR Member Since: 29 Sep 2013 Location: Horsham Posts: 25
Yup! - so long as the ignition is actually off. Some stuff stays powered for some time after. However, on mine the front two sockets go off immediately with the key and the load space one stays on. I'm guessing this is configurable in software as different people seem to have different combinations? Si |
Not software configuration on that year, can only have been a modification by someone. Bodsys Brake Bible
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025
My front one and rear one go off with ignition off. Tested them both with sat nav plugged in and it flashed up no power message when car locked.
| myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433
Very helpful, thanks all. Can't wait to get home and find out if mine are same. |
Si What year is yours? * Current: 2024 D350 Defender 90 on coils! * Current: 1974 Lightweight 2.25L petrol. Old skool * GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * 1949 80" in family since 1975 I use www.glenrands.co.uk Great independent specialist! |
If boot stays live then plug it in there and perhaps leave it on the roof ? The boot seal should be ok taking the lead width. Keep us posted! * Current: 2024 D350 Defender 90 on coils! * Current: 1974 Lightweight 2.25L petrol. Old skool * GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * 1949 80" in family since 1975 I use www.glenrands.co.uk Great independent specialist! |
Will do. It comes with 9 feet of cable so I might have the option to plug into the boot and place it on the dash. |
Early 2006, 55 Plate Si |
Thanks Bodsy! As it happens, it suits me as I leave my Waeco Fridge in the back which just runs when the battery voltage is high enough (or at least switches off before it's flat!) . Si |
Did you try it out of the boot? I suspect its ignition live though * Current: 1974 Lightweight 2.25L petrol. Old skool * GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * 1949 80" in family since 1975 I use www.glenrands.co.uk Great independent specialist! |
Not yet but should get to it today. It was late when I got back home last night. |
Do a search on "access mode" and you'll see its wise to put the car into access mode when you park up especially for longish period. Its shuts everything down and the car goes to sleep. Battery power saved |
I do always leave the car in access mode as it makes it easier to get in and out and this has become the habit.
| All times are GMT |
