Home > General > SOLAR BATTERY charger - do they work?
Page 2 of 3 <123>
Bodsy
Site Sponsor
Have you let the car go fully to sleep to make sure it stays live all the time. I thought they were Ign switched, but it could be 'car awake' switched I guess?
Have you sat in the car and let it go to sleep fully (even locking the car whilst you are in there (double lock to switch off the interior alarm)) Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #464688 Mon Jun 15 2015 7:17pm
myfirstrrs
No but that would explain why it didn't take any charge. I'm back from a business trip tomorrow night so will give it a go.
Thanks for the idea.
Post #464691 Mon Jun 15 2015 7:30pm
SimonR
myfirstrrs wrote:
In my simplistic world that means that it is permanently live. Is that correct?
Yup! - so long as the ignition is actually off. Some stuff stays powered for some time after. However, on mine the front two sockets go off immediately with the key and the load space one stays on.
I'm guessing this is configurable in software as different people seem to have different combinations?
Si
Post #464699 Mon Jun 15 2015 7:50pm
Bodsy
Site Sponsor
Not software configuration on that year, can only have been a modification by someone. Bodsys Brake Bible
See it HERE
Post #464702 Mon Jun 15 2015 8:01pm
DrRob
My front one and rear one go off with ignition off. Tested them both with sat nav plugged in and it flashed up no power message when car locked.
Not tested the boot one. Probably permanent live. * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #464706 Mon Jun 15 2015 8:27pm
myfirstrrs
Very helpful, thanks all. Can't wait to get home and find out if mine are same.
Post #464708 Mon Jun 15 2015 8:29pm
DrRob
Si
Si
What year is yours? * Current: 2024 D350 Defender 90 on coils!
Post #464709 Mon Jun 15 2015 8:33pm
DrRob
If boot stays live then plug it in there and perhaps leave it on the roof ? The boot seal should be ok taking the lead width. Keep us posted! * Current: 2024 D350 Defender 90 on coils!
Post #464710 Mon Jun 15 2015 8:35pm
myfirstrrs
Will do. It comes with 9 feet of cable so I might have the option to plug into the boot and place it on the dash.
Post #464713 Mon Jun 15 2015 8:39pm
SimonR
Quote:
Si
What year is yours?
Early 2006, 55 Plate
Si
Post #464718 Mon Jun 15 2015 9:04pm
SimonR
Thanks Bodsy! As it happens, it suits me as I leave my Waeco Fridge in the back which just runs when the battery voltage is high enough (or at least switches off before it's flat!) .
Si
Post #464722 Mon Jun 15 2015 9:10pm
DrRob
Did you try it out of the boot? I suspect its ignition live though Big Cry * Current: 2024 D350 Defender 90 on coils!
Post #464870 Wed Jun 17 2015 6:13am
myfirstrrs
Not yet but should get to it today. It was late when I got back home last night.
Post #464875 Wed Jun 17 2015 6:59am
DrRob
Do a search on "access mode" and you'll see its wise to put the car into access mode when you park up especially for longish period. Its shuts everything down and the car goes to sleep. Battery power saved Thumbs Up * Current: 2024 D350 Defender 90 on coils!
Post #464887 Wed Jun 17 2015 10:56am
myfirstrrs
I do always leave the car in access mode as it makes it easier to get in and out and this has become the habit.
So, when the car is awake, all three lighter sockets are live, when the car goes to sleep, all three sockets go to sleep, including the boot socket.
It seems that my only way now is to make one of the sockets permanently live. Has anyone done this? I have just searched the forum without success.
Post #464917 Wed Jun 17 2015 2:50pm
Page 2 of 3 <123>
