Home > Technical > Air suspension compressor running all time and very noisy.
Tigerdon
Northern Ireland 2006 Range Rover Sport Supercharged Java Black
Hi as well as problems I'm having with cats on my SC, I've also noted that the compressor is practically going constantly, ie noting it going everytime I'm sitting in traffic etc
It's also very noisy
My local LR dealer has said it's probably on way out, for record a brand new one was fitted in dec 2011 and car has done 17000 miles since then
My question is: does it need replaced and if so who's cheapest to get one from?
2006 RRS SC
Post #396590 Sun Sep 29 2013 10:09pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
Tigerdon, see here...http://www.rrsport.co.uk/gallery/albums/userpics/10097/SB034_SB036%20Vehicle%20Enhancement%20Program.pdf
When you had the compressor replaced in 2011, did they also do the software upgrade ? - its a known fault for certain VIN vehicles around the age of yours. Mine is a similar age SC and had the same problem.
Good luck. Carl
Post #396593 Sun Sep 29 2013 10:44pm
Disco_Mikey
That bulletin is now 7 years old. I would be VERY surprised if any cars "slipped through" without having had the remedial work carried out.
Regardless, in this case the compressor has already been replaced.
I would be checking for air leaks, especially around the air reservoir, and dryer unit. Both common issues.
While the cover is off, check the aluminium bracket closely. The are very guilty for corroding away around the mounting points that hold it onto the chassis rail.
If the bracket is OK, and you are happy there are no air leaks in the system, then suspect the compressor Thumbs Up
Post #396598 Mon Sep 30 2013 6:36am
Tigerdon
Ok guys took truck to LR and was advised the following
AFTER A DAIGNOSTIC CHECK WE FOUND THE FOLLOWING REPAIRS NEEDED
AIR SUSPENSION FAULT
COMPRESSOR RUNNING ALL THE TIME
THIS MAY BE AN AIR LEAK BUT WE NEED TO REPLACE THE COMPRESSOR FIRST
PART COST
COMPRESSOR £494.21
PIPES £40.85
LABOUR £180.00
So I replaced the compressor at my local LR specialist
Guess what still the compressor is coming on quite regularly
How do I know if I've a air leak and just wasted another £550?
Post #397211 Fri Oct 04 2013 10:07pm
This is one of those situations where the garage shouldn't be allowed to charge you if they don't fix the issue. Just changing a part and hoping it solves the problems is just poor service. If they change something and it doesn't fix the issue then why should the customer pay? 2012 SDV6 - it's missing a couple of cylinders
Post #397226 Sat Oct 05 2013 12:48am
Tigerdon
I'm hearing you mate, seems to b a case that if computer is unable to diagnose problem then they r clueless
If I have an air leak how can I tell?
And where should I be checking?
Any links would b great
Thanks
Post #397235 Sat Oct 05 2013 7:27am
DrLex
Iceland
It's not uncommon to have the relay stick, so the compressor runs constantly; did the dealer check it?
Post #397315 Sat Oct 05 2013 7:05pm
B3EEE
Wales 2005 Range Rover Sport Supercharged Vesuvius Orange
Mines in at the moment with similar problems and the garage are checking it for air leaks, sensor/relay failures and electrics BEFORE assuming its the compressor. If its working all the time, it isn't faulty. Faulty is when it don't work at all. PS, mine is overheating  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Prefer RR Vouge S/C but they don't do Orange !
Post #397321 Sat Oct 05 2013 8:13pm
Tigerdon
We'll mines is brand new
Post #397421 Sun Oct 06 2013 6:32pm
