| RRSPORT.CO.UK | ||
|  | Home > Technical > Air suspension compressor running all time and very noisy. |
| V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145    | Tigerdon, see here...http://www.rrsport.co.uk/gallery/albums/userpics/10097/SB034_SB036%20Vehicle%20Enhancement%20Program.pdf
|  Sun Sep 29 2013 9:44pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | That bulletin is now 7 years old. I would be VERY surprised if any cars "slipped through" without having had the remedial work carried out.
|  Mon Sep 30 2013 5:36am |
| Tigerdon Member Since: 28 Sep 2013 Location: Belfast Posts: 35      | Ok guys took truck to LR and was advised the following
|  Fri Oct 04 2013 9:07pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | This is one of those situations where the garage shouldn't be allowed to charge you if they don't fix the issue. Just changing a part and hoping it solves the problems is just poor service. If they change something and it doesn't fix the issue then why should the customer pay? 2012 SDV6 - it's missing a couple of cylinders
|  Fri Oct 04 2013 11:48pm |
| Tigerdon Member Since: 28 Sep 2013 Location: Belfast Posts: 35      | I'm hearing you mate, seems to b a case that if computer is unable to diagnose problem then they r clueless
|  Sat Oct 05 2013 6:27am |
| DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257    | It's not uncommon to have the relay stick, so the compressor runs constantly; did the dealer check it? | ||
|  Sat Oct 05 2013 6:05pm |
| B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450      | Mines in at the moment with similar problems and the garage are checking it for air leaks, sensor/relay failures and electrics BEFORE assuming its the compressor. If its working all the time, it isn't faulty. Faulty is when it don't work at all. PS, mine is overheating  | ||
|  Sat Oct 05 2013 7:13pm |
| Tigerdon Member Since: 28 Sep 2013 Location: Belfast Posts: 35      | We'll mines is brand new | ||
|  Sun Oct 06 2013 5:32pm |
| Posting Rules
