![]() | Home > Technical > Air suspension compressor running all time and very noisy. |
| V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145
Tigerdon, see here...http://www.rrsport.co.uk/gallery/albums/userpics/10097/SB034_SB036%20Vehicle%20Enhancement%20Program.pdf
That bulletin is now 7 years old. I would be VERY surprised if any cars "slipped through" without having had the remedial work carried out.
| Tigerdon Member Since: 28 Sep 2013 Location: Belfast Posts: 35
Ok guys took truck to LR and was advised the following
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159
This is one of those situations where the garage shouldn't be allowed to charge you if they don't fix the issue. Just changing a part and hoping it solves the problems is just poor service. If they change something and it doesn't fix the issue then why should the customer pay? 2012 SDV6 - it's missing a couple of cylinders
I'm hearing you mate, seems to b a case that if computer is unable to diagnose problem then they r clueless
| DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257
It's not uncommon to have the relay stick, so the compressor runs constantly; did the dealer check it? |
| B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450
Mines in at the moment with similar problems and the garage are checking it for air leaks, sensor/relay failures and electrics BEFORE assuming its the compressor. If its working all the time, it isn't faulty. Faulty is when it don't work at all. PS, mine is overheating |
We'll mines is brand new |
| All times are GMT |
