Home > Maintenance & Modifications > Miss fire on TDV8
Embo
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
Miss fire on TDV8
When starting from cold ive noticed that there is a slight miss-fire and small puff of grey smoke on my 07 plate RRS TDV8 , this only lasts around 2 seconds and is fine after and when started when the engine is warm . Any ideas what this could be ? there are no warnings on the dash board . thanks in advance ..
Post #378239 Mon Mar 25 2013 6:17pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
Mine used to do this and it was a egr valve, cleaned it with egr cleaner and its fine now
Post #378241 Mon Mar 25 2013 6:20pm
Embo
This might sound silly , but where do i find the egr valve ?
Post #378245 Mon Mar 25 2013 6:35pm
cossiedave
they are pretty hard to get to, all i did was take the intake pipe off then start engine ,rev to 2500 rpm the squirts egr cleaner in in short burst
Post #378254 Mon Mar 25 2013 9:03pm
GAZB
My 2.7 TDV6 does the same when I start from cold in a morning , for 5 - 10 seconds it blows out alot of smoke and idles a but lumpy for a few seconds , I was told it could be glow plugs , apparently alot of them break when you try to remove them so its off with its head if this happens which is ££££ , im hoping its this cold weather and it stops when the temperature rises
Post #379069 Fri Mar 29 2013 12:32pm
GAZB
Post #379070 Fri Mar 29 2013 12:32pm
