Home > Maintenance & Modifications > Miss fire on TDV8 |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
Mine used to do this and it was a egr valve, cleaned it with egr cleaner and its fine now |
Mon Mar 25 2013 6:20pm |
Embo Member Since: 13 Nov 2012 Location: Newcastle/under/lyme Posts: 23 |
This might sound silly , but where do i find the egr valve ? |
Mon Mar 25 2013 6:35pm |
they are pretty hard to get to, all i did was take the intake pipe off then start engine ,rev to 2500 rpm the squirts egr cleaner in in short burst |
Mon Mar 25 2013 9:03pm |
GAZB Member Since: 02 Feb 2013 Location: NORTH WEST Posts: 83 |
My 2.7 TDV6 does the same when I start from cold in a morning , for 5 - 10 seconds it blows out alot of smoke and idles a but lumpy for a few seconds , I was told it could be glow plugs , apparently alot of them break when you try to remove them so its off with its head if this happens which is ££££ , im hoping its this cold weather and it stops when the temperature rises |
Fri Mar 29 2013 12:32pm |
